- Feb 8, 1999
- Robert Harris
William Wyler's terrific 1953 Roman Holiday is one of those problem films. It's also a bit of a mystery. There are a handful of early 1950s Paramount black & white production, for which the OCNs are simply no longer extant. Some understandably were copied to safety and destroyed.
But one might question why Roman Holidays, a film shot in Rome (and on Melrose) in mid-1952. Were they using up the final stocks of nitrate in Rome?
Regardless, there have been several attempts at being Roman Holiday back into form, and this new 4k from Paramount adds a tiny bit of extra detail (grain) via a higher data throughput.
Is there anything about the current master that's 4k? Dream on. Not even 2k, so the earlier Blu-ray should be quite sufficient under the circumstances.
But one must give Paramount credit for going above and beyond in trying to eek out the very last drop of image from the extant dupe.
Gray scale is fine. Decent blacks, good stability. There's no downside here, but the question remains that unless one is a super-fan of the film, and also a 4k addict, is this a viable upgrade?
I can't answer that question. The numbers below tell the story.
Image – 3.75 (HDR)
Audio – 5 (Dolby TrueHd Monaural)
Pass / Fail – Pass
Makes use of and works well in 4k - 4
Worth your attention - 10
Upgrade from Blu-ray - If you love it and want the tiniest incremental advantage
Slipcover rating - 2 (it's shiny)
Very Highly Recommended
RAH
Image – 3.75 (HDR)
Pass / Fail – Pass
RAH
