RobertMc
- Jun 2, 2004
Hey Guys,
I thought I would drop in a picture of my completed flexy rack but in trying, I have run into the old problem where I can't post a URL because I haven't done enough posts. UPDATE - I can now put a link in!
8 Shelf Flexy-rack
Anyway, the project has taken a while, but was a lot of fun and I think that the finished product looks great (humble opinion). In any event, the rack certainly meets my needs with room to spare for when my system grows...
Some details,
Height: 990mm (39")
Width: 560mm (22")
Depth: 500mm (19 3/4")
MDF: 16mm (5/8")
All Thread: M16
Each shelf, apart from the top board, has three holes drilled towards the back for cable management (power cords in one, interconnects in another, speaker cable in the other). This has worked a treat and I am proud of the cable management I have managed to achieve!:b
The rack has 8 shelves - yes 8. The number was more or less decided by the way that the MDF sheet was cut up in size for me, and I decided that it wouldn't do to waste any. There are two spare shelf openings at the moment, but down the track I can see a DVR and possibly a Sat TV box.
I had a good look around all of this forum for flexy rack hints and tips, so thank you to all of you who have ever made one of these and shared your results with the rest of us - helped with the inspiration. Thanks also to TNT-Audio, where I believe the rack design may have originated (or spawned / morphed / bred?).
I am in the process of putting a few more photographs of the rack and construction in the Member's Theatre Gallery. See under "The BAYVIEW-ODEON"
Comments and criticisms?
8 Shelf Flexy-rack
Some details,
Height: 990mm (39")
Width: 560mm (22")
MDF: 16mm (5/8")
All Thread: M16
