Kevin Beck
- Jan 4, 2001
Hey guys,..
Doing a little clean up, and have a set of 3ft. Belden 89259 interconnects that I built a while back, and then only had hooked up for a couple months. They have been setting in a drawer over the winter, as I unhooked them when I purchased a new processor, and now don't plan to use them. These cables are suitable for analog audio, digital audio, and component video. Extremely versatile.
I have 7 - 3ft. cables. If you only need 6 for a multi channel input set, that's fine also. If you need more than these, or something of a different length, I can build what you need as well.
3ft. Belden 89259 cables with canare RCAP connectors, Techflex covering, 3M glue lined heat shrink, and internal connections treated with Caig 5% connection enhancer gold spray, for long corrosion free life. $22.00 ea. plus ship.
I will have a set of 7 - 3ft. Belden 1695A cables, with an added shield for sale in the near future. These cables are every bit as versatile as the 89259, only, in raw form the 89259 has a slight edge on the 1695A in the shielding dept. However, with the added extra shield, these cables are a real problem solver, if you have any stray RF, or EMI floating around your system. These cables will be listed for $25.00 ea. plus ship.
Any questions, feel free,....
