I'm picking up my new 3803 tonight. Any tips for breaking in this beauty? I had planned on running the receiver with the TV for a couple days straight. Would this be the best way to go?
Receivers do not require breaking in. After thirty minutes (or less) of being switched on, they reach proper operating temperatures and that's that. Look at this way: If a piece of electronic gear (receiver, preamp, power amp, tuner, etc.) did require a break-in period, then it wasn't properly designed.
I concur with Mr. Briggs. I would though, leave the unit on for a while and make sure that all the features on it work. For example, if you're thinking at some point of using the unit as a pre/pro, see if you can borrow an amp to ensure there aren't any issues.
