Elyse
- Nov 21, 2002
I've been reading here and learning a lot. I'm hoping that I can get some opinions to help me make a decision.
My old receiver (Kenwood vr-407 - basic HTIB deal) needs to be replaced because the s-video circuitry is starting to go. I don't want to spend a ton of money on a receiver because 1) my speakers aren't that great (I may be upgrading them a bit), 2) the room is only about 13' x 15' with 5.1 surround (couch on the wall), and 3) I'm saving for a bigger TV. However, while I'm cheap (originally looking under $300, less being better), I'm also picky and have a musical background, so I want something good that won't break down in a year.
I went to Circuit City and Tweeter (because they're close) to look at current models. I didn't like the H/K build at all, and I wasn't impressed by the Denon exterior quality (note that these are cheaper models), so I'm leaning more towards Pioneer, Yamaha, or Onkyo.
At Tweeter, they had an open box Yamaha RX-V1400 receiver (nothing but the receiver and the setup mike) for under $400. Considering the features for the price, I bought it at least to try for 30 days. However, I've been having second thoughts as to whether it's actually what I need / worth the money *for me*. If it's worth the extra money (even over a Pioneer 1014, which would be a little less), then I'll keep it.
I guess I'm looking for feedback as to whether the build quality, sound quality, etc. of this mid-range receiver is enough to offset using the extra $100-$150 or so to start upgrading my speakers instead. Obviously it has more features, but I'm not sure they're features I'll ever use. I do hear a difference between this receiver and my previous one (not a surprise), even without any calibration.
My needs: 5.1+ sound, dts-es / dd-ex / pro logic II etc., dvd-audio inputs, component switching (at least 2), s-video switching (at least 3), high switching bandwidth (at least 50 mhz, but the higher the better), excellent sound quality, good reliability
Nice but not required: Component transcoding / up-conversion so switching only needs to be done on the receiver - however, while it won't improve picture quality, I don't want it to degrade it (its useless to me if it does). Some sort of speaker equalization / room setup.
I use the setup for about 80% video and 20% music.
Question:
I see a difference in picture quality between running S-Video / Component inputs through the receiver and running them straight to the television - extra shimmer and slight color difference. It's possible that I would have seen this with my old receiver as well if I had compared. It was more pronounced with component conversion but also could be seen with normal s-video switching. Is this standard or a shortcoming of the Yamaha 1400? My current TV is nice but only SD - I hope to upgrade within the year.
The other receivers I was looking at before I saw this one were: Onkyo TX-SR502 or TX-SR602, Pioneer VSX-D814, Yamaha HTR-5740
Slightly above price range (but in line with the 1400): Kenwood VR-8070, Pioneer VSX-1014, Yamaha HTR-5760
(I know this was very long - if you've read this far, thank you, and I appreciate any insight you have into whether I should stay with the Yamaha RX-V1400, get a better one in the same price range, or save my money for the rest of my system.)
Question:
