ScottCHI
- Feb 21, 2004
hi. new to this forum. looks like a great place to ask questions, so here i go!
as the denon manual and website are not very informative, i'm wondering exactly how the bass mangement works on this receiver; particularly, how it works when playing non-DD/DTS signals, like 2-channel audio. is it different?
if i have ALL my speakers set up as "small" and the receiver's crossover set as 80Hz, what is the nature, exactly, of both the low and high-pass filter, in that circumstance, when playing 5.1 digital audio versus 2-channel audio. i'm specifically wondering what is happening to the signal coming out of the sub output; is there a traditional 24db/octave low-pass filter or not and is the bass management the same with this setup whether 5.1 digital or 2-channel audio, or is there some difference in the sub out signal when playing 5.1 digital audio relative to 2-channel audio with this setup? the reason i'm asking this is because, if i follow the manufacturer's (deftech) instructions for my sub when using a receiver's bass management, and set the sub's crossover as high as it will go (150Hz), it doesn't really "sound" like the bass signal is "filtered" above 80Hz, when listening to 2-channel audio.
now, what about when the front speakers are set up as "large", but the rest are set as "small"? i DO understand the utility and workings of the "LFE only vs. LFE+main" setting when listening to DD/DTS material, but what is the nature of the signal coming out of the receiver's sub out in that instance (fronts as "large") when listening to plain 2-channel audio? is it "unfiltered"?
thanks in advance for your time!
Denon3803
KEF Q5 fronts
KEF Q9c center
KEF Q1 rears
DefTech Prosub200TL
Denon3803
KEF Q5 fronts
KEF Q9c center
KEF Q1 rears
DefTech Prosub200TL
