Anyone know where I can pick up used or referbed Crown amps? Specificly a CE2000, I tried Audiogon but there were only 2 amps on there. I'd like to avoid paying 600 for a CE2000 if possible.
I decided on the QSC RMX1450. It puts out 200 watts less at 4 ohmns than the CE2000 but the sub I'll be powering with the QSC can only handle 500 watts, I figure 50 watts won't make to much of a difference. I'll check in WinISD. If I need more volume in teh bass area, I'll just build another sub. The QSC will only be amping music below 80 hz. Also, are there any amps that are made just to amp low frequency sound?
not in the market here Russ, but which QSC's are you selling? regarding the crown amps, you might want to check with local places like Guitar Center as they may have some stock.
