Darren Gross
- May 16, 2001
I've had a Loewe Aconda 30" for a year or so now and am quite happy with it....except I can't get it to accept a Progressive scan DVD player through the component jacks. It displays 480i great, but the second I switch it over to Progressive, wham! the picture doubles, split down the middle and won't work. :frowning: I've tried two separate progressive players through friends and got the same results from both.
I want to upgrade my non-progressive DVD player to one that is progressive, but if it's not going to work I don't see any reason to spend the money.
I've researched a few threads here on this but still have questions:
Does the sets 480i imaging equal that of a progressive player due to the sets line doublers and automatic progressive circuitry?
And if having a progressive player hooked up will improve the image quality that strongly, do I need some intermediary connector, instead of the component cables?
Sort of a sidebar, but is there a way to switch thesidebar coloring on 4x3 programming to gray instead of black to reduce eventual burn in?
Any tips would be tremendously appreciated!
The manual states nothing about having to switch something on to get progressive to work....
Thanks!
D
Thanks!
D
