AlexGoodman
- Jul 4, 2002
Hi, I have gone through a number of receivers over the past few years, and was hoping you might be able to give me some advice. No receiver cost more than $500. I had an HK not reproduce bass and also emit a loud buzzing, even when turned off, a Pioneer have a channel go out, and a Yamaha stop working after a several weeks (I can turn it on, but it doesn't play anything). Could it be because they were powering 2 4-ohm speakers (Ascend Acoustics CBM-170s)? Is there a particularly reliable brand out there I should consider? Should I get 8-ohm speakers? Thanks.
