Anthony V
- Aug 22, 2002
Set-up
Sharp XVZ-9000E
Denon 3800 via YUV
Stewart Firehawk 110'' diag.
Problem:
Slightly green tint on faces
Dear all
I have calibrated with AVIA and color bars are good.
When looking at the color-bars through the blue filter everything seems fine.
Checking the test-pattern with the 3 colors and % I have following results:
Blue 0 to +5%
Green -5%
Red 0 to 5%
So it looks pretty close to what is possible.
Strangely enough I still have a slight greenish tint with flesh-tones.
Where or what do I have to change to correct this problem ??
Gamma ?
Even when using Gamma Standard that has a flat curve the problem persists........
Would accessing the service-menu and changing the gains have an effect ?
I have my settings here as a reference in case some Sharp users whant to add their comments.
R Bright 128
G Bright 128
B Bright 128
R Gain 104
G Gain 95
B Gain 97
In the User Menu
Contrast: +3
Brightness: +1
Color: +4
Tint:+3
Red:+2
Blue:-1
Gamma 1
Col Temp -2
800 Ansi Mode
Maybe having the Color at +4 is a mistake an pronounces the greenish tint having to go to +3 with TINT ?
I know it's all question of personal taste but is there a general rule not to exceed Color 0 ???
What is the starting point ?
By choosing Color +-XX I then can compensate with tint +-XX so .....
BTW choosing Color +1 as a starting point and then changing TINT still will give me the greenish look....
Taking the color value lower than 0 will result in a lack of color and "punch"
Is this something that can be corrected with the projector settings or will I need some sort of a filter to compensate the green tint ?
PLEASE HELP
PS: Sorry 1 post and already too many questions
Anthony
Sharp XVZ-9000E
Denon 3800 via YUV
Problem:
Dear all
Blue 0 to +5%
Green -5%
Red 0 to 5%
Gamma ?
R Bright 128
G Bright 128
B Bright 128
R Gain 104
G Gain 95
B Gain 97
In the User Menu
Contrast: +3
Brightness: +1
Color: +4
Tint:+3
Red:+2
Blue:-1
Gamma 1
Col Temp -2
800 Ansi Mode
PLEASE HELP
Anthony
