MattD
- Feb 29, 2000
New In box Canon PIXMA iP6600D Photo Printer. Asking $150 shipped. Retails new for $200. UPC has been removed for rebate purposes.
What's in the Box:
PIXMA iP6600D Photo Printer, iP6600D print head, power cord, FINE cartridges: CL-51 color, CL- 52 photo, documentation kit, easy setup instructions, Canon Photo Paper Plus Glossy for Borderless Printing 4" x 6" sample pack
Product Description:
The PIXMA iP6600D Photo Printer is a photo-printing powerhouse, with incredible quality and high end convenience. It delivers an amazing resolution of up to 9600x2400 dpi, for detail and clarity that will surpass your expectations. To achieve this, Canon Full-photolitho-graphy Inkjet Nozzle Engineering (FINE) uses a next-generation 3,072-nozzle print head that ejects precise, consistent droplets as small as 1 picoliter. More nozzles plus smaller droplets means smoother, virtually grain-free images. Plus, high intensity Photo Cyan and Photo Magenta is added to the conventional 4 inks, to increase the accuracy of color values. With the extra-large 3.5 inch LCD color viewer and control panel, evaluate and enhance the images on a compatible memory card before printing. For viewing, just insert the card into one of the built-in card slots and select the images. As needed, the PIXMA iP6600D Photo Printer will automatically correct for red eye, improve sharpness and enhance the light values on faces. Or, fine tune the image using the easy control panel. Then, print directly from the memory card. Print directly from a PictBridge compatible digital camera or DV camcorder. Even print directly from an infrared-enabled mobile phone. Just shoot and print. And for Bluetooth-equipped mobile phones, PCs and PDAs, this versatile printer is Bluetooth compatible with the optional Bluetooth adapter allowing you to print from another room. Borderless 4x6 photo in approximately 46 seconds Direct photo printing from select memory cards and PictBridge ready devices Windows XP, Me, 2000, 98, Mac OS X v10.2.1 to 10.4.x Dimensions - Width 17.3 x Height 6.8 x Depth 10.3(D) inches
What's in the Box:
