Ted Drain
- Oct 3, 2002
Has anyone built a Flexy rack using black oxide finished steel rods, washers, and bolts from McMaster-Carr? I've seen a lot of people painting stainless steel and plated steel but it seems like this would be a lot better.
You can check them out at (the part # is 94210A150):
http://www.mcmaster.com/param/asp/ps...75;2 55=18523
They have a wide variety of black oxide parts. Does anyone know the quality of the finish? Does it look good enough to leave as is? Is it better to try and paint stainless steel?
FYI: I really wanted to build a Flexy using stone shelves but the price is way too high for me. I'm going to try and build the shelves using an MDF base with solid wood trim and use a 2' x 2' fake marble ceramic tile (or something similar) as the visible shelf material. Something like this:
