HowardPM
- Aug 17, 2002
- Howard
I have a philips 34PW850H its a 34 inch HDTV Widescreen Tube. Anyways when watching stuff in thats in 4:3 ratio on my Philips TV the edges of the picture begin to wave/weave. Rather then being a straight edge down the TV. I'm using component cables to connect from my cable box and according to Philips, you can't use that type of connection to watch standard TV you need to switch to SVIDEO. Now I'm pretty sure I had this same issue back before when using SVIDEO though I always kept the screen stretched so it was hard to notice.
Any ideas?
Any ideas?
