rkelley1408
- Aug 27, 2015
- Ryan
So this is my first time posting here, and I was hoping someone could answer a question I have about setting up my home theater.
I have recently purchased a Yamaha RX-V377 receiver with HDMI. I wanted to use this to switch inputs to my TV so I wouldn't have to switch inputs on the TV as well. However, for reasons I won't go into, I do not have the option of having a cable box which means I need to use the TV's built in tuner.
My question is, is there a way I can use HDMI control and/or audio return channel so that when I set my stereo to TV, the TV will also switch to the TV input and the stereo will receive the audio from the TV? Then ideally when I switch to any other input on the stereo, it will switch the TV to th HDMI input so it will receive the HDMI pass through from my stereo receiver.
I have never used HDMI control before, so I'm not sure if this is possible.
Thanks!
Thanks!
