Fist time PJ buyer looking for a unit that meets several criteria:
-LED, to save from expensive bulb replacing
-1080P
-3D support
-Picture quality that at least comes off as sharp (me and my novice friends won't be able to tell if the blacks are truly super duper black, et cetera)
-Enough lumens to be visible in a moderately dark room (blackout curtains on the window, shutters on the sliding door)
-WiFi would be nice, to stream from my computer. Not a deal breaker though
-Android OS for flexibility's sake
-Moderate silence in operation. The use of booming surround sound makes this not a huge deal, but sub-leafblower levels of fan noise would be nice
SOOOO...
http://www.aliexpress.com/store/product/2014-New-Arrival-Luxcine-Z2000SD-2205P-Blu-ray-3D-DLP-LED-Mini-Projector-1500-Lumens-Android/300840_2039778734.html
This unit here seems to check and double check those points above, but is a bit on the... well.. shady Chinese manufacturer side. Aliexpress storefront with broken English in the descriptions, that sort of thing.
So my question is: Is there anything on the specs that justify the low price? Is there any offering from a more well vetted manufacturer that ticks the boxes and costs about the same? Also the unit is 1200x800 native, as many appear to be. Will that deliver a good 1080p image? Is the 1500 lumens enough? Whats the deal with the odd 2205p resolution? Any input would be greatly appreciated.
SPECS PULLED FROM THE LINK ABOVE:
Lens:
Manual focus with 1080P resolution
is_customized:
Yes
Resolution:
1280*800
Brand Name:
LUXCINE
Style:
DLP
Portable:
Yes
Use:
Business & Education
Home Theater Projector:
Yes
Brightness:
1500 Lumens
Projection Distance:
0.3m-5m
Type:
Digital Projector
Lamp:
Super Bright LED Osram Q7
Model Number:
Z2000SD
Contrast Ratio:
4001:1-5000:1
Weight:
1.4KG
Supported resolution (Max):
1920*2205
OS:
Android 4.2.2
Color reproduction:
16.7 Million
Lamp life span:
>30000H
Throw Ratio:
1.22:1
Image Aspect Ratio:
16:10 & 16:9 & 4:3
Video Inputs:
HDMI*2, USB*2, Memory Card Slot, Composite Video RCA, VGA D-Sub
Audio Outputs:
Digital Optical TOSLINK, Headphone Jack
-1080P
-3D support
SOOOO...
Lens:
is_customized:
Yes
Resolution:
1280*800
Brand Name:
LUXCINE
Style:
DLP
Portable:
Yes
Use:
Yes
Brightness:
1500 Lumens
0.3m-5m
Type:
Digital Projector
Lamp:
Model Number:
Z2000SD
Contrast Ratio:
4001:1-5000:1
Weight:
1.4KG
1920*2205
OS:
Android 4.2.2
Color reproduction:
16.7 Million
Lamp life span:
>30000H
Throw Ratio:
1.22:1
Image Aspect Ratio:
16:10 & 16:9 & 4:3
Video Inputs:
Audio Outputs:
