SONY str-dn1030 + HT-XT1 no FM Tuner (1 Viewer)
nonnenmacherh
Heiko Nonnenmacher
Hi,
my problem: I'm not able to get the radio (FM Tuner) output of my SONY STR-DN1030 to my soundbar SONY HT-XT1 which is conntedt using HDMI. Radio is fine cause sound on the headphones is working!
Also i see the informations off the tuner on the TV
The same issue if I try to play music using USB or CD from the CD-player connected via cinch.
during my vacation I took the chance to put all my AV-Devices together. there is a
* AV-Receiver SONY STR-DN1030
* Soundbar SONY HT-XT1
* Bluray-Player LG (HDMI)
* CD-Player (Chinch)
* TV SONY KDL-40Z4500
* SAT-Receiver Kathrein UFS922
I've connected
(STR-DN1030) HDMI out HDMI1 (HT-XT1) HDMI OUT HDMI1 (TV)
Any Idea?
Al.Anderson
Al
You don't use an active soundbar (one with an amplifier) with a receiver.
So either (1) return the soundbar and get speakers to go with the receiver, or (2) connect the TV to the soundbar using the optical input, and return the receiver.
schan1269
HTF Expert
Chicago-ish/NW Indiana
Sam
Why are forums getting littered(not just this one) with..."My AVR and (self-powered*) soundbar don't work together"...They will never work together, aren't intended to be used together.*Often have zero clue what means.
Nielmb
