Bose Lifestyle 25 (Acoustimass SubWoofer) + Pioneer VSX-D514 (1 Viewer)
BokaLike
Boka
Hi,
I'm new to this forum & wanted expert's advise over connecting Pioneer VSX-D514 to Bose SubWoofer (Lifestyle 25 Acoustimass).
But the problem is: I don't have any other accessories that came alongwith with Bose SubWoofer (8-Pin Din-Connector Cable...etc).
I got only Sub-Woofer, Nothing Else.
I wanted to use it as Only Sub-Woofer & I'm NOT going to use any other out-puts of Acoustimass Subwoofer. Because my 4 satellite speakers are already connected with Pioneer VSX-D514.
Can anyone please help me to connect Bose Acoustimass Subwoofer to my existing Home Theatre (Pioneer VSX-D514) Setup?
If you guide me, I can open-up the Subwoofer & solder wires directly to 8-pin Din-Socket's inner side.
Thanks.
BoKa
schan1269
HTF Expert
Chicago-ish/NW Indiana
Sam
Acoustimass Bass Module.It is not, and should not be confused as a subwoofer.There is no way, at all, to do this...and there is no point.
Alf S
BANNED
Alfer
Agreed. Time to go subwoofer shopping.
Put that bass module on Craiglist.
BokaLike
Boka
Sam & Alfie, Thanks a lot for clearing my confusion.
Earlier I thought that Acoustimass Bass Module is a Sub-Woofer. But now you people cleared my mind.
Sure I'll go for new sub-woofer, But what to do with this Bass Module?? Is it TOTALLY WASTE??
BOKA
Feetman
