Blu-ray Home Theatre System to Cable box? (1 Viewer)
Motafota
Alx
I don't have a AV Receiver, and I bought a Blu-ray Home Theatre System which I want to work with my cable box. It only has a HDMI output, no input. But it does have an unfamiliar input called Optical. I want the speakers and everything to work along side with the cable box so i'm wondering if I need to return it and buy an AV Receiver with speakers instead? I'm not sure how the Optical connection would work or if it's Optimal for me. My cable box is HD, so i'm not sure if the Optical connection would give it Quality of an HDMI or Component. What should I do to get the set up that I want?
Thanks in advance!
schan1269
HTF Expert
Chicago-ish/NW Indiana
Sam
Optical is an audio standard that is still in its infancy(compared to other connects, like analog).
It debuted in 1983.
You buy one of these, and connect the STB(HD Cable box) to the HTiB...
http://www.ebay.com/itm/3rd-Party-NEW-3ft-toslink-auido-cable-/200869958236?pt=US_Audio_Cables_Adapters&hash=item2ec4c8525c
papill6n
