I need a Portable Sirius solution (1 Viewer)
Philippe Kline
Hey everyone, please don't hate me for rehashing a topic that's been covered, but I'm just feeling frustrated today... Can you guys help me out w/a list of portable Sirius options and what's required?
Here's all I need:
- Ability to listen to Sirius in my car(s), hooked up to my HT (w/gooood audio, ideally), and potentially hooked up to something at work.
- Reasonable cost; I'd like to keep it ~100, but I can probably push my budget up to $150 if absolutely necessary; getting Sirius in my car is the #1 goal right now, though (I can buy more docking stations/kits later on.)
Concerns:
- I'm living in an Apt and have been told that I can't really have anything installed on the house (dishes, antennas, etc...)
- I don't need to be able to have Sirius playing simultaneously at all these locations, so a portable (plug 'n' play/multiple docking stations) solution would be ideal.
- As far as installation... I really need something simple that doesn't involve any drilling or wiring in my car(s.)
...that should be it, I think. Can anyone help me out?
Chris
Look at the sportster replay and a dock. While you can't mount anything to the roof, generally if you can sit it on your window sill or something similar you can get decent signal (at least I can).
But the sportster replay is movable, can easily go from car to your house, and has about the right cost. The New Version 4 units are out, so you can get one of those or pick up one of the older units probably at a pretty steep discount.
Similar Threads
Nielmb
