Zach M
- Jan 14, 2000
It's long, but please bear with me because I need some help.
Ok, here's the story: my dual Tempests each in their own 10 cu ft enclosure have been done for about a month now, and I can play them!
I bought a used Carver M-500 magnetic field amp off of ebay about 3 months ago when I started building the subs. It was adversited in perfect working condition. When I received it, it had a repair shop sticker on the back, but it was confirmed again by the seller that it works perfectly. Not having my subs done, I could not test it so I trusted him. When one of the subs was finally finshed I hooked it up (correctly) and it played fine for a while, and then blew a circuit. I installed a new 15 dedicated circuit for the amp, and it worked again until the amp blew its own 10 amp fuse. Replaced the fuse, and it blew again. I was out of ideas so I took it to a shop (this was ~1 month ago). The shop jacked around for 3 weeks, not being able to find a Triac part. I got on the internet for a grand total of 3 minutes and I found the part, and had it shipped directly to them. I got the amp back yesterday with the new part, paid the $130 they charged, and hooked it up to one of my subs. It played fine for about 2 minutes, and the fuse blew (acted the same way it did a month ago before the "repair"). They now have it back, and they are going to 'let me know', which probably means another two weeks.
Now for the questions: Even though it was about 3 monthes ago when I bought the amp, should I try to contact the seller who told me it was working perfectly and see if he'll pay half the repair or something? I don't know if it is even worth it because if I were the seller, I would probably think whatever he did with the amp for 3 monthes is his own problem. Should I e-mail him?
Second question: what should I do about this amp??
I know it will never be reliable. Should I sell it, cut my losses and buy a new Mackie with warranty or something? Or do you think this amp has a chance of working out for me in the (distant) future? Any other suggestions?
Thanks for any advice you can give me for the ugly situation. It is getting f**king ridiculous and I'm tired of it. And again, sorry for the length.
My Home Theater
My Home Theater
