Jay H
I have an '02 Toyota MR2 Spyder with a bad rattle coming from the driver side woofer. I want to take my door panels off and fix it but I keep thinking while I'm there, I might as well replace the woofer/tweeter combo with something fairly decent.
On a MR2 forum, I'm told that the 6.5" JL Audio XR650CSis are great and I'm also told that they pretty much bolt right into stock woofer form and the tweeter box. However, they are also JL's top-o-the-line model and I'm not really thinking that I need that kind of speaker that's about ~$250. Do any of you know anything about the cheaper JL speakers. I'm more interested in value and ease of installation. I also hear a bunch about MB Quart 216s which are cheaper at around $150 per set.
I am going to try to reuse the existing wiring, hook up the crossover in the doorpanels and go from there. Everything else in my audio system is stock and will remain that way for now.
Jay
Jay
