Another cable box problem...help! (1 Viewer)
Mirko
I have a Motorola digital cable box provided by Adelphia here in Fullerton, CA.
The only output on the box is coaxial cable and video composite (the yellow RCA cable) as well as white and red audio output. The local Adelphia office, as well as their installer tell me that I can hook up the box to my receiver using the yellow composite as well as the two audio outputs. He says he's done it many times. The tech on their 800 number tells me that the composite outputs on their boxes don't work and I should route the signal thru a vcr. Don't want a VCR. I got a new replacement box from Adelphis today and still no go. It's like they want me to go to a dish!
I have a Yamaha RX-v630 receiver and a Panasonic plasma TH-42PWD6. My Yamaha outputs to the Panasonic via a three color component cable (Green blue and red, I think). My DVD is connected to the Yamaha via three color component as well as two RCA jacks for audio. DVD player works fine.
My cable box, however is a problem. I have the yellow video cable from the cable box connected to the appropriate input on the Yamaha and the two audio cables connected to the Yamaha as well. No signal, audio or video. The Yamaha site says that their receivers like it when all connections are of the same type. Is this right? My DVD is connected to the Yamaha via component and the output from the Yamaha to the Panasonic is also three color component.
What can I do so I can get cable channels from the digital cable box to my Yamaha and displayed on my Panasonic. Adelphia informs me that they will have HD boxes soon that will have component outputs and that will solve my problem then.
Thanks to all for your help. Hope I'm getting my component and composite right. That's why I mentioned colors as well. If I screwed up, please help me get smarter.
By the way, the Panasonic is bitchin' and for less than $3,000.
Mirko
DavidES
If you are using the receiver to switch video like I think you are, then you'll ALSO need to run a composite cable from receiver "tv/monitor out" composite (yellow) to tv composite (yellow) "in" to watch the cable and setup tv for that input. Receiver doesn't change video format. Composite in to composite out. Same goes for S-video and component. Although it kinda sucks because you'll have to switch tv inputs everytime. If you're going to do that, you might as well connect both dvd and cable box video outs directly to appropriate tv inputs bypassing the receiver to get best quality picture possible since you'll need to switch tv inputs anyway.
Hope this helps
Mirko
David,
I thank you for your response but I am still mixed up. I've only had this thing set up a few days now and I got too stressed trying to figure it all out so I took a break and enjoyed watching DVD's for a while.
I have a hard time figuring how to connect the DVD directly to the monitor. If i do that, how do I switch from DVD to cable box. Does the monitor give me the ability to do that? You are not suggesting that I plug and unplug cables everytime I switch from DVD to cable are you? I always thought the receiver would be the "brain" of my system.
I want to keep the component video out to from my receiver to the in in my monitor. That much I know. Unless you think composite video would give me as good of a picture. If I go composite from the receiver to the monitor, would both the DVD and cable work then?
sorry to be so confused but I know I'll get the hang of this. They sure as hell are not going to make these be everyday consumer items unless they make them easier to hook up!
Thanks again.
Looking for more input.
ChrisWiggles
Ok, I'm not familiar with your TV, but presumably it has BOTH component and composite inputs (component being the 3-cable connection that you are using from your DVD, and composite being the single yellow from your cable box). You can deal with video switching in two main different ways:
1) Directly to the display.
This method eliminates video switching, which, especially on recievers can sometimes degrade the signal. Many times on recievers, the component switching does not have the bandwidth to pass full HD signals, so picture degradation may occur.
2) Use your reciever as the video switcher
This runs all your video through your reciever, and lets IT act as the video switcher, which can simplify changing sources. Rather than having to switch audio on the reciever, and then switch video inputs on the TV, one change can do both.
Your situation has two different video methods, composite, and component, and your reciever will not change one into the other. So, if you have component coming in (from your DVD), you need component going out to your TV. And since you ALSO have composite from your cable box, you ALSO need to run another composite cable to your TV. Unfortunately, this probably means that you'll STILL have to switch sources manually on your tv, in which case you might as well run everything direct to your TV and save the cost of another cable run. Then again, cheapie video cable for composite isn't that expensive at, sawy radio shack, and should more than suffice.
As for the audio, I do not see why it's not working if you are using your reciever to deal with the audio from the cable box (which i'm assuming is what you're trying to do). You will need to go more in-depth more likely, in terms of what your audio problem is. With the stereo jacks connected, you should be getting audio through your sound system.
Lastly, I noticed that you had your DVD player connected via stereo jacks. I'm assuming you have a surround sound speaker system with your reciever, in which case you NEED to use a digital connection for the audio, either coax or optical (coax is cheaper, and if you want to get REALLY audiophile-picky, arguably better too), or you will NOT be getting dolby digital, only pro-logic II. Hope this helps, and clears some things up. This should get the video up and running, as for the audio, we may need more info.
Good luck!
DavidES
I just realized something. If you want the On Screen Display aspect of receiver, you'll need the composite out of receiver to composite in of tv unless your receiver outputs its display over component.
It should if it has separate types of inputs.
You would need to read your equipment owner's manuals to setup correctly especially your tv's manual.
Hope this helps and everything that ChrisWiggles posted is most accurate also,
Mirko
Actually, I am paying for the most expensive premium package and this is the latest and greates box Adelphia offers in my area. Composite or straight cable output only and even their 800 support number tells me that the composite output is dissabled in all their Motorola boxes (which I have). Their local tech denies this.
I'm thinking of just giving up and going with some kind of dish but have had no replies to my inquiries re: Dish vs. cable on that section. I didn't come to America to have to put up with this crap from cable. Their boxes are such clunkers.
You know, all this may be second nature to you, but there is no way to get up to speed in a few days. There is so much technology to learn about. I guess that's why it's a hobby. I notice there are no microwave hobbysts...they just work!
scott>sau
Mirko, DCT cable boxes like scienctific Alantic come stock with SP/DIF and S-Video output connections. The Motorola and General Instrument boxes have sheet metal stamped over the SP/DIF and S-Video outputs. You have to send the box to Texas and they solder these connections into the PC board. Get on Adelphia, they can do it.
Ted Lee
it sounds like you're trying to convert a composite signal (from your cable-box) to a component via your receiver?
as already mentioned, chances are your receiver isn't capable of doing this. afaik, only the higher end models are currently capable of that.
i bet if you ran composite cabling it would all work. try running the composite monitor-out to the tv...
this is easy to test. just run a composite wiring from the cable-box to your tv's composite input. see if you get a signal or not.
Jake K
Really!, I've talked to numerous Adelphia people on the phone about the lack of digital audio connections and they never said anything about this. It does say Dolby Digital on the front though. Not that it matters, I'm going DirecTV, I've had enough crap from Adelphia.
scott>sau
I worked for Adelphia for years. There were two times the client DEMANDED we give them true Dolby Digital as it states on the front of the cable box. So we sent the box away to have the connections soldered in. They threatened to walk to dish. Having the digital audio and S-Video connections is determined by the cable provider.
I don't blame you about going to Dish Network, or DirecTv. Adelphia is a dishonest corporation. I do not mean that in slander it is a fact. That is why I resigned. The main reason the people at the call center could not help you will digital connections is they don't know what they are and they only know what profit is.
James_K
Mirko,
We are in the same boat. I have Adelphia digital cable here in Diamond Bar, CA.
Seems like the only way to get the signal is route thru a VCR. I guess I'll stick to this connection when they roll out HD in a couple of months.
annabelleaardvark
john steward
just for the record, the MOTOROLA DVR (model DCT 6416) in front of me now, & supplied by Time-Warner, has functioning COMPONENT, COMPOSITE, & S-VIDEO connectors. What I need is a hot FIREWIRE output so I can go into my DVD burner. The only digital output is HDMI.
Nielmb
