What would I use to upscale cable and SVHS to progressive for ae100? (1 Viewer)
Chris PC
DELETE THIS THREAD IF YOU HAVE A CHANCE :)
What could I use to upscale NTSC cable TV signal and SVHS signal to progressive for an AE100 LCD projector (856 x 484)? Looking for the least expensive. My PC right now has a Matrox G400 max Dual-head. I could get the rainbow runner to use as video input. Could I use some software to line-double, squeeze and zoom a 4:3 widescreen image?
What software?
thanx
Matt DeVillier
get dscaler and a compatible input/capture card, it's the best solution out there short of a $500+ holo3d card. don't waste your time with the rainbow runner.
Chris PC
Moderator, if you see this. Delete this thread..my other older thread has more info in it so I'm posting there. Better to build on that.
Thanx :)
balajipackersmovers
