Sebastian
- Apr 14, 2002
TX-DS484's bass management was inevitable. With no sub, full-range material goes to each of the speakers and any LFE .1 channel material is discarded. If you have a sub, it gets the LFE and any bass below 80Hz if the main speakers are set to "Large," rolled off at 12dB/octave. Speakers designated "Small" are crossed over at 120Hz instead, with a 6dB/octave slope. While far from comprehensive, I suspect the configuration options available here are sufficient for a typical surround buyer. If you have either a set of mostly full-range speakers all around or a subwoofer and a set of smaller satellites, like most smaller home-theater speaker systems, one of these modes should suit you fine. The main group that's shortchanged here are people who have large front speakers and smaller rears but no subwoofer
Even called Onkyo to confirm this
Actual website
The tones are 40 Hz so I should be getting nothing if the bass management is correct. The only time I should have any signal on the main speakers is if I have the sub option set to no.
I will test again to make sure i did not screw anything up and will test with sub set to no and see if that changes anything.
What would suggest setting my speakers for HT use? Large or small. I have HTD level II 5.1 set. 5 1/4 drivers I think on the mains.
