This is really hard to describe, you really ought to go to Home Depot to check this out.
The Toro is sounding interesting to me. Do you know which model you have?
I think I paid $259.
The least expensive Personal Pace Model is the 20017 Recycler and it costs $359 at Home Depot. I wanted to include a link to it, but when ever I copy and past the url for it, it goes to a search results screen, not directly to the mower.
I found a Toro 18in Stright Shaft gas powered bruch cutter that also comes with the trimmer attachment. It's attachment capable and apparently uses 2-cycle engine oil. It costs $199 at Home Depot.
According to the Home Depot site, straight shaft trimmers will last longer.
Late last year I got an electric to replace my reel mower
There goes the polar caps... (Welcome to the dark side)
I bought a used mower for $60 from a friend's neighbor. It's adequate. I then mowed a large rock and sheared a cotter pin. It's now a $100 mower :b
My favorite choice for new was the Toro Personal Pace. Very nice mowers.
I bought an electric Black & Decker trimmer for about $50 at Home Depot. It seemed a good compromise -- good ratings in Consumer Reports while not being too expensive.
After much research and debating between the Honda HRX and the Toro SR4 I settled on the Toro. I really like the features of the HRX but the price put me off. Then the Toro not only went on sale at the local ACE hardware, but Toro also had a $40 rebate going so it was a done deal. I was very pleased with this mower. Easy to push with their Personal Pace system
The Super Recycler is their top-of-the-line. They do have Recycler line of which one (the 20041) was named a CR Best Buy. I couldn't find that model anymore, but CR says they 20017 is similar and Home Depot sells it for $359.
Does anyone use a line trimmer for edging? Gas or electric? I'm looking for ideas on those too.
BTW, we've got a big yard, pretty flat though.
I may get a gas edger before the season... The Toro (sorry, no model #) is a four stroke engine, which is gas only. It runs cleaner and quieter and starts easier.
I thought you already had a gas edger/trimer?
I do but in an earlier post I stated that it was the one attachment that didn't work properly. It seemed to lug the engine.
If you had it to do over again, would you still buy the Toro? When you just use the string trimmer as an edger are you happy with it?
