Aaron Baker
Grip
- Mar 29, 2003
I realize there have been other areas that touched on this subject but I have a "slightly" different angle.
I have a Pioneer 45tx and I started noticing a hum. Can't recall if it just showed up or its been there for awhile. I know it has just recently annoyed me. I have a dedicated outlect for my system. I use (good or bad) Monster 5100 conditioner. No cable tv hooked up. The hum can be halted when I use the "mute" feature on the receiver. Volume has nothing to do with it. Doesn't matter if it is up or down volume of hum is exactly the same. Any ideas?
Thank you
Thank you
