Michael Osadciw
- Jun 24, 2003
- Michael Osadciw
Guys
This is my understanding of DTS terminology:
DTS = 754kbps
DTS-HD = 1536MBPS (original legacy DTS before they slashed the bitrate in half)
DTS-HD MASTER AUDIO = their lossless audio compression
I'm not even sure if DTS knows for sure what name is for what...press has been so mixed on naming their options. DTS-HD used to mean lossless...and their website has a pamplet on that hinting at that...but since the original announcement things have changed and I can't seem to find any other info from them (maybe I'll call). I think they renamed 1536kbps to DTS-HD because of Dolby's "upgraded" lossy compression Dolby Digital Plus.
If this is the case, FYI, then DTS-HD at 1536Mbps is fine transferring over S/PDIF (Coax or optical). That is the "legacy" bitrate before DVD really put the pressure on them to slash the bitrate or risk disappearing entirely.
Pat, for your comparison of the full-bitrate DTS soundtrack vs. the Dolby Digital Plus option, I think it would be more fair to use the decoders and Digital-to-Analogue Converters (DACs) in the Toshiba. There are too many variables that come into play if you don't do this - the sound will change no matter what.
If you send out the DTS audio to the Denon receiver (that most likely uses better DACs than the Toshiba) that'll change the sound right away even if both codecs sounded identical. Plus, the cables you use from the 5.1 channel outputs will alter the sound too...and what is the quality of everything before the outputs of the Toshiba on the other side of that 5.1 panel? That may or may not give DD+ an advantage.
If you process everything inside the Toshiba, at least you know the only thing that is changing is the audio codec. All else is the same.
Mike
DTS = 754kbps
Mike
