elston
- Sep 5, 2003
To give you a quick answer, yes! Different amplifiers do sound different however, the differences may be subtle. Most solid state amps of decent design will sound very similar unless driven at a decent level. You may then notice that bass can become 'muddy' or treble frequencies can become shrill.
Well designed amps will sound more similar than not. If you play your system at more than just 'normal' listening levels then you may experience problems with the amplifiers power supply not being able to supply the output devices with enough current to control the speakers voice coils properly. This would be interpreted as a loss of definition of bass notes, or sloppy bass.
Amps that are driven too hard, beyond their power rating would clip the output signals therefore creating distortion. This would be heard as sharp or exaggerated high frequency. This can also burn out tweeters if left playing too long.
If you deal with a reputable dealer, ask for a loaner amp so you can perform some comparisons with your own gear. If you can't hear a difference, then don't worry about it. Just enjoy the sound.
