Now performing their hit single, "A Love as Rare as Ours" and their upcoming radio single "Baby's Got Babyback!"MarkHastings said:Cute....then I can have them sing backup for me and go out on the road as "Mark and the Briquettes"?
I just noticed my link doesn't work. I tried recreating it and it still doesn't work. If you want to see this cooker go to www.homedepot.com and search for orion cooker.Johnny Angell said:I just saw this Orion Stainless Steel Cooker in the newspaper insert. Here's a link to it on their web site:
http://www.homedepot.com/prel80/HDUS...gmm.0&MID=9876
I've never seen anything like this before.
MarkHastings said:And don't forget when I used to cook in my fireplace...remember my old hit song: "I left my Hearth in San Francisco"?
Buy one of these:DaveF said:
I'm still learning to not dry out my chicken breast, but I'm getting there.
Actually, the foil tent is for the rest period off the heat. Meat has to rest in order to let the juices redistrbute. If you cut into a steak, chicken, pork, etc., right after it comes off the heat the juices will leak out and it will be dry. A rest lets the meat relax and the juices are reabsorbed into the fibers of the meat.DaveF said:I have such a thermometer -- very helpful. I've not tried foil.
My basic process is cook each side 4-6 min, flipping only once. With your suggestion, I'd put the foil tent over for the second half. I'll try that next time.
Part of the challenge is the chicken breasts are very thick at one end and thin at the other. Cooking the thick end properly leads to an overcooked thin end. I've not tried cutting it to more equal sized portions.
Doesn't the meat cool down a lot in 5-7 minutes even with the foil tent?Jeff Gatie said:Cook over medium-high heat until 165 degrees and put under a foil tent for 5-7 minutes to let juices redistribute.
Actually, no. There is a thing called "carryover" that can cause the inside to increase in temperature as the juices settle, depending on the size of the cut. Letting meat rest is a basic step in proper preparation. Every chef on the Food Network hammers this home any time they cook a steak, chop, etc. A large roast sometimes has to rest for 15-20 minutes and you have to cook it to slightly below the desired temp in order to account for the large amount of "carryover" heat.Johnny Angell said:Doesn't the meat cool down a lot in 5-7 minutes even with the foil tent?
Part of the challenge is the chicken breasts are very thick at one end and thin at the other. Cooking the thick end properly leads to an overcooked thin end. I've not tried cutting it to more equal sized portions.I would bet if you are charcoaling them then you are cooking them directly over the coals, try indirect heat. Move the coals to one side of the grill and cook chicken on the other side. They will cook a little slower and allow the inside to get caught up with the outside without burning the outside.
Sorry for the gravedigging of this thread, but I just had to share.MarkMel said:Anyone have one of the new grills with the infrared burners? I was looking at a few of them and wondering if they work well.
I use the 3 burner "turbo" gas grill sold by Barbeques Galore. It's really heavy duty but not cheap - current price around $600. But you get what you pay for... Mine is 14 years old and still going strong.
Actually now my Turbo BG is closer to 20 years old and still going strong.
A hint about salmon: get the salmon steaks, not the salmon filets. You know, the ones where they cut inch thick slices at 90 degrees to the backbone and leave the skin on. These won't fall apart on the grill and can easily be turned with a spatula. Just oil the fish up first with some hand-rubbed peanut oil. Molto bene!
