Tim Glover
Ditto Chuck. Haven't seen this film in YEARS. And would love to see in Blu-ray. Bought it when it first came out and returned it after the reviews came in.
Another thing to note - the slipcover and the cover insert of the old disc bear the serial number, in the very right corner of the back cover, of
11111016517
My remastered copy, bought this morning, has this serial number on the slipcover. But the cover insert inside has this new serial number...
11111016515
Originally Posted by Mike Frezon
Bleddyn:
If you are talking about the UPC bar code "sku" numbers, they are usually 10 digits long (two groups of five numbers--with two smaller numbers on each end of the string).
That is excellent information that the sku # of the remastered version ends in "5"...but I fear you may be off by a digit.
Originally Posted by James Lee
Ugh. Well in that case, I'd ignore the presence of the rebate sticker and just go with the serial number ending in 515 on the inner paper insert.
Originally Posted by Bleddyn Williams
I'd go by the printed info on the case insert, not by any rebate sticker, James. They are probably an old batch of slipcovers still being worked through. I had the $10 sticker on my slipcover, but nothing about the offer inside!
No, Mike - I'm talking about the small print serial number that is at the bottom right corner of the back cover. Nothing to do with the UPC. Check it out!
11111016517
11111016515
Hopefully this will help!
