Gregory Suarez
- Aug 23, 2005
Okay, so I got a new Onkyo TX-SR805 receiver with HDMI 1.3 inputs. I realize that the Toshiba A1 CANNOT pass 5.1 Dolby TrueHD/Dolby Digital-Plus audio as raw bitrates from its HDMI 1.1 output. That's fine, the player can do the audio decoding.
Now, here's the problem: I was under the impression that 5.1 DTHD/DD+ audio could be decoded in the player and passed to the receiver via HDMI as a PCM signal instead of having to use the six analog RCA cables. I have my A1 set up to pass audio from the HDMI output as PCM, yet when I play HD-DVDs with DTHD audio the player's on-screen display reads that the audio is being output as "Bitrate" instead of PCM. However, when I play standard DVDs the on-screen display correctly reads "PCM." What I'm afraid is happening is that the DTHD tracks are being downsampled before being output to HDMI.
Does anyone have any idea why this is happening? If I upgrade to the XA2 (with HDMI 1.3) will I have the same problem?
