Jay Morrissette
- May 13, 2002
I just bought an Onkyo 898 to replace my Newcastle 945. I needed more digital inputs and a receiver that was more wife friendly. The Onkyo excels in those. But the sound is kind of weak when compared to my Newcastle.
Is the problem in the amp or processor?
Should I add a 3 channel amp for the front? Or should I sell my car and buy a Lexicon MC-12 and some killer amps.
What I really want are 3 NHT-Pro A-20 monitors up front. They are 250 watts per channel and sound incredible! I use them at work. They are about $1500 per pair http://www.nhtpro.com/pro_productInfo.asp?ProductID=3
Plus the center would be about $850. Maybe I can consider that for next years budget.
But for now would a decent used 3 channel amp solve my problem, or is the processor section the problem?
~Jay
~Jay
