Jodie
- Feb 27, 2001
I can get the Sony SAWM40 and the JBL PB10 for about the same price. Is there a clear winner here? Thanks for the help.
I'd go with the WM40 for HT (a bit better extension) and PB10 for music (a bit tighter).
I myself find that the PB-10 extends lower than the SAWM.
While the Sony is rated at 20hz and the PB-10 at 27hz, I did not find that the Sony put out 20hz at any significant db, I believe the PB-10 will put out a significant db at 25hz.
I don't think the Sony really comes on until above 35hz, and the PB-10 comes on strong at 30hz and possibly below.
While my PB-12 is rated at 25hz, with my room configuration and room modes, I am clearly and loudly enjoying frequencies below 15hz!
Hmmm... I had the Sony and it was clean to 25Hz (with an F8 around 22Hz). Stuffing it really improved the "tightness" of it considerably too.
Ok Jerry.
I will say that the Sony is pretty dang good sounding for the price. And I am curious as to how it sounds being stuffed
