Alex-C
- Apr 18, 2000
Here is my situation. I just got my DSL installed. I also purchased the Linksys Wireless Access Point/DSL router + 4 port switch and a wireless PCMCIA card for my laptop.
Now I installed my switch/router and no problem. The desktop still has DSL, and everything seems to be working and I installed the wireless access card in the laptop, again no problem installing it. The configuration utility that comes with it indicates a strong signal - so it sees the wireless access point/router and is getting a good 1.2 Mbps throughput.
I need some help on what the heck I do to tell my laptop to access the internet using this device. Everything seems to be working, I just can't access the internet on my laptop through this card. There is nothing in the manual telling you how to set this part up.
Do I have to set up a TCP/IP protocol with the access card ? If so, what are the settings ? Right now, on my internet connection settings, I dont have any dialup, or anything selected. I tried setting up various TCP/IP protocols but no luck. All the time, the card is working fine. Its getting the signal....
I am looking for some place on the web where I can ask general discussion questions like this. I already tried Linksys, and their support is bad, no way to talk or email or discuss with a tech person.
Grrr....
Grrr....
