OK. Well, if were up to me, I would not get a plasma just yet. But we need to put it on a wall where nothing else will really work.
Here are my choices here:
Gateway 42" Plasma
Samsung 42 inch Plasma Display, PPM-42S3
Planar PDP-42BK w/ Desk Stand Bundle
Viewsonic 42 Inch Plasma Display With Built-In TV Tuner VPW425
Planar 42" Plasma Display ( Widescreen 16:9 Screen Ratio ) - PDP-42BK
Which one do you recommend? These TVs are around my budget.
Also, we'd like to get some professionals to install this for us - wall mount it and run the wiring. Are there any good pros will do this in the Long Beach, CA area?
Thanks!!!
Gateway 42" Plasma
Thanks!!!
