Nelson Au
- Mar 16, 1999
Hi guys,
I thought I'd post about the set-up I'm playing around with and perhaps gain some insight from you.
About 2 years ago I added the Oppo 105 to my HT system. It's primarily the blu ray player, but also plays CDs and SACDs. I knew it could play audio files and one attraction was the asynchronous USB DAC.
I'm an Apple guy, so I have CDs that I ripped in iTunes with Apple Lossless. I was using the Asynchronous USB DAC connection from my MacBook Pro to play iTunes through the Oppo. Works great! I send the audio from the Oppo to my Rotel Pre-Pro 1572. I use the Multi input by-pass. So it's not processing the audio as I'm letting the Oppo's Sabre DAC do that. I like its sound better then the Rotel. But they both sound great.
Last year I learned that Oppo now supports Apple Lossless files, that's great, glad they finally did that! I got the firmware update then. So I've been experimenting with a thumb drive and loaded some ALAC files and FLAC files. Some CDs I have allow FLAC downloads so that's great. I used the front panel USB port to connect the drive and it plays great through there. Very convenient.
One of the reasons I bought the Oppo was because it can accept so many audio formats and processes them well with the on board DAC. Also the asynchronous USB was something I liked. However, now that I've learned that you can play ALAC files and I have FLAC which won't play on a Mac, I'm looking at setting up a large hard drive and using that with the Oppo and leaving out the laptop and desktop Mac altogether. Makes sense. I also have an Apple TV.
So the question is, if the asynchronous USB port mostly is for the benefit of files being played out from a computer, then if I use a hard drive, the asynchronous connection isn't something needed? The Oppo doesn't have to synchronize the files from a computer anymore if they are coming from a hard drive. IIRC, there's a second USB port in the back of the Oppo so I imagine connecting to that will be the way to go from a hard drive. I'm also thinking it's not necessary to pass the audio connection from the Apple TV should I want to stream from my Mac desktop. I would think if the hard drive has my audio library, it's best to go direct to the Oppo. I want the Oppo to process the audio and not be altered by anything in the path.
Then the other thing is it would be nice if the display doesn't have to be on to view what files are playing. I thought Oppo had an app. But the last time I tried it, last year, it didn't do what I wanted. Maybe the app is improved. I'll check it out again, I just thought it would allow the user to see what's playing from the hard drive Into the Oppo and allow you to control what songs to play from an iPad.
So any thoughts and experiences from the members here would be appreciated and interesting! Thanks.
Oh yeah, one of the really annoying things about the Rotel is it's on board HDMI sensor that detects what kind of audio is coming in has a delay before it can decide what kind of processing to do. So it mutes the audio for the first second or two so you miss the intro to a song or the start of a program on DVD/Blu Ray, not sure anyone here experiences that. I understand smaller builders like Rotel don't have the budgets to build up the HDMI of the processor. Classe has the same problem. So I find using the by-pass and allowing the Oppo to process the audio gets around that. Just a shame because I paid for the processor that I won't use. I do use the Rotel's processor for movies.
Edit: I realized that maybe I posted this in the possibly wrong section? Maybe it should be in the Blu Ray players section? Or even the HTPC section?
