Leon Van Dongen
- Mar 21, 2001
Hi guys, wondering if you could help!
I have a 51cm LG Flatscreen TV, about 5 months old. The problem is that the top half of the screen is sometimes 'bent' towards the left..say for instance there is a vertical line on the screen, instead of being straight up and down it looks like this.
instead of
Not very clear, I know
I brought it into a repair shop under warrenty and they said there are no adjustments for it and they wouldn't fix it
Know, I've been playing around with it lately and I've noticed the problem is really bad if the screen is even relativly bright. If I turn the brightness/contrast down to about 50% most of the 'bending' goes away but is still slightly noticeable. I have noticed that in movies when fading to different scenes it corrects itself dramatically when fading out, ie when the screen isn't as bright. Any ideas on how to fix this permemently, as I would like to have my screen a touch brighter?
instead of
