Kwang Suh
- Sep 4, 1999
Can you change aspect ratio with the PLAYER while in progressive out (a la the Panny RP91)?
Yup. You use the remote and go into the menu system and change it on the fly.
I believe you can add side bars to 4x3 material but not zoom non-anamorphic letterbox a la RP91. Someone please correct me if I am wrong.
Yup, you can also zoom as well.
The chroma bug only manifests itself when the player is in progressive mode.
Actually, this is incorrect. The chroma bug is a problem inherent in the MPEG decoder of a DVD player - which is why references to the MPEG decoders are made when discussing the bug. Progressive capability comes courtesy of the deinterlacer.
For example, Toshiba players exhibit the bug, and they use the Genesis deinterlacer. The Panasonic RP-91 also uses the Genesis chipset, but does not suffer from the bug - this is because the two players use different MPEG decoders.
Also note that the Sony 7000 DVD player is highly regarded as an interlaced player because of absence of the bug - but the 7700 _does_ have the bug.
Jeff
"They're coming to get you Barbara..."
I have the same question. How do you know if it is passing blacker than black?
You would need to look at a PLUGE test pattern. VE has one as do the Optimode tests from THX.
If a player can't pass BTB, then you will see black clipping (similar to white clipping) on DVDs that contain BTB info. (Paramount DVDs tend to pass BTB.)
