To use bananna plugs or not on hk 525 and jbl s-38-s? (1 Viewer)
Todd smith
I have a hk 525 and 2 pair of jbl s-38's. Do I use banana plugs or not? If so I was planning on getting the $6/pair gold plated ones at radio shack.
Obviously my goal is to get the best sound/connection for my speakers, receiver and speaker wire. Will banana plugs help me here or not?
If so is there any special trick to using them?
KyleGS
The best sound/connection would be bare wire tightened down and left alone. If you plan on unplugging the speakers often you may want the ban. plugs for convenience- otherwise they will not do anything for the sound.
John-Miles
Yeah the plugs are jsut neater and mroe convenient, either way though there should not be much a difference. you would certainly get more of a difference by using thicker speaker cables.
annefnlys01
