Patrick Sun
- Jun 30, 1999
My earlier thread on this topic got eaten up by the HTF Borg collective somehow, so below is a hastily pasted together bits and pieces of my journey into the world of DIY sonosubs:
June 25, 2000
Okay, I got tired of not having any decent power tools, so after a dose of Home Improvement's Tool Time, I went to Home Depot and came home with a Skil Plunge Router (which I may not use depending on whether I want the drivers recessed), Ryobi 5" sander, Black-n-Decker Power Drill (4.5A, corded - didn't want to run out of power, ya know), and Black-n-Decker Jigsaw (with easy blade attachment contraption). That was about $185 of tools, but it'll be worth it since it'll also me to build some flexy racks down the road too, and maybe full-range speakers again.
Now I need to get some 3/4" MDF, and the sonotube (24" diameter), some 8" PVC pipe, a dual speaker binding post plate, and some misc. bits and pieces, different types of coarseness for the sand paper, some glue, liquid nails. Then the fun begins!
I think I will go with a dual 12" Shiva water heater sonosub 24" wide, 8" port - tuned to 18-19Hz, 12 ft^3, one driver on top, one on the bottom.
June 26, 2000
Last night, after checking out one Home Depot and finding no 3/4" MDF at all, I went to another one 5 miles away. I lucked up and was able to I picked up 2 sheets of 3/4" MDF (24"x49") for the endcaps, the bonus being they were pre-cut and fit in my lil' Honda Civic with the rear seatback folded down. I also picked up 2 sheets of 1/4" plywood (24"x24") to be used so that the t-nuts have something to hold on to for the inner endcap.
Here's a question, I also bought 48" of Quikrete tube (it's like sonotube but a lil' thinner). I will cut it down to around 27" for use in the sonosub. I found one which had the closest inner diameter of 8" that I was looking for to use as the port.
June 27, 2000
Here's a couple of raw material shots:
Photo 1
Photo 2
Photo 3
The other Shiva driver is currently in use in another sub enclousure.
Like I said, I needed to start buying some power tools, so this is a good opportunity to "prove" them into my daily budget of life.
If I can get a truck, I will bring home 2 6 foot sections of 24" sonotube tomorrow morning. That will be the final piece of the puzzle, all that's left is the elbow grease.
I will buy the cloth material covering up the sides of the sonosub later, but I'm thinking of doing it up in a lighter hunter green color.
June 28, 2000
I got my buddy to bring home the two 6 foot long sonotubes for me. Yeah!
Well, finally got the endcaps done and the circular cutouts too:
Photo 4 - me before cutting the stuff.
Photo 5 - Router at work.
Photo 6 - make sure the endcap would fit by cutting a 3-4" piece of sonotube off and use it for the "fit" of the endcap.
Photo 7 - holes for the parts to be cut into the endcap.
Photo 8 - Ta da! Holes cut out for the driver/port/terminal cup.
Photo 9 - this is me after all that cutting up of MDF.
PatCave ; HT Pix ; HT Gear ; Pat's DVDs ; Link Removed
June 25, 2000
June 26, 2000
June 27, 2000
Photo 1
Photo 2
Photo 3
June 28, 2000
