Petetheman
- Apr 18, 2009
- Pete Housing
Hi, I'm looking for some advice on using a (passive?) speaker splitter.
Instead of sending an amplified signal to the splitter and then off to the speakers, my intention is to send the signal straight from the desktop PC's soundcard, straight to the splitter. I'm assuming that the signal coming from the sound card is either unamplifed or very weakly amplifed as you would see in a pre-amp sort of signal. Once going through splitter, it routs as follows:
1) PC front speakers by way of subwoofer which must be where it gets amp
2) Home Receiver/Amp (for watching movies via the TV)
3) Remote transmitter which then sends signal to powered speakers
4) travels 40 feet to upstairs Amp (15x2rms)
This is the unit I'm installing:
Amazon.com: Monster Cable SS4 Multi-Speaker Selector: Electronics
My main concern is that I'm not damaging my amps or speakers by underpowering them or by splitting the signal the way I am doing. My "splittler" (linked above) is supposed to be used with the amplifer in line BEFORE the splitter. I plan to use it in the opposite manner. Does this propose a problem to signal strength?
Also, this particular splitter has "amplifer protection" which is supposed to be turned on whenever multiple speaker outputs are being used. This "protection" can be turned on or off. Can someone explain to me what such protection is needed and what the dangers are. I'm confused. Should I even need to use it considering how I plan to install? I really need some basic information on how speakers and amps are damages by low volume or weak signals. I'm confused on why this occurs and how to prevent it.
Any comments appreciated!
