thegekko77
- Jan 23, 2022
- Joe Sheets
All.
I am creating a few simple remote macros for my setup.
I have a Samsung un55nu6900fxza with a Cable box on HDMI 1 and a Roku box on HDMI 2. There is also the native Samsung TV as another source.
The macros I want to create are:
1) Turn on all devices and set to HDMI 1 (To watch cable)
2) Turn on all devices and set to HDMI 2 (To watch Roku)
3) Turn off all devices
The problem I am running into is that there is no way to select a discrete input source (at least that I have found). To select a Source with the remote, you have to press Source button multiple times to step through the 3 sources to select one. So, when I am designing these macros, I can't select a specific input. I tried to just add multiple Source presses to arrive at the correct input, but that won't work because, depending on what source you left off at when you shut the system down, you will need different Source presses to get to a specific input.
It seems like there should be a way to get around this but I haven't found one yet. Is there a way to get the TV to default to a specific input when turned on?
Looking for any suggestions!
Joe
Joe
