Nathan Stohler
- Jan 17, 2004
- Nathan Stohler
Mike, you've made a key point in your last post. Knowing the price and brand of a cable and even seeing the cable affects our expectations.
For you "believers", I challenge you to conduct a simple blind test between your magic cable (A) and a generic cable of similar shielding and gauge (B). Have a friend connect the two cables (you don't know which is A and which is B). Switch back and forth between the two as many times as you like. When you've heard both cables to your liking, your friend will flip a coin. If the coin turns up heads, he'll play cable A. Otherwise, he'll play cable B (without you knowing which is being played). Now, see if you can correctly pick which cable is being used.
If you can pick it correctly, great. If you can pick it 16 times out of 20, I would be astounded.
