Screen Cleaning - Newbie goof! (1 Viewer)
CraigB
Alright, I did something I'm sure we all do. I was so anxious to see and hear my system running with the surround sound that I fired up Saving Private Ryan before everything was completely installed. The short of it is that a German 88mm blast knocked the center speaker off the top of the TV. The speaker wasn't attached to anything.....I was anxious, remember. The speaker survived the fall to the floor without any problem.
However, (did you know this was coming?) on the way to the floor, it hit the screen of my new Sony KP51WS520 RPTV and some of the plastic on the speaker is now on my screen. The screen isn't damaged but has the plastic streak on it from the speaker. I tried rubbing it off with a moist soft cloth but to no avail.
Anybody have any idea how to remove it? Appreciate any input....
Mort Corey
Try a moist micro fiber cloth. They seem to get stuff off that a regular cotton cloth won't.
Mort
Nielmb
