World Wide Stereo
Question on flush mounting a 60" Grand Wega into a wall (1 Viewer)
Jason Cald****
Hi i was wondering if i could flush this into the wall without having to worry about overheating issues. I have a bookcase now that i tore out and have the room and depth to do it. I just wanted to make sure overheating would not be a issue.
Any advice will be much appreciate.
728x90
Mike Wilk
On another well known forum, there are several posts regarding one man's project to do the same, with pictures. From my experience with a 42WE610, I can say there is a heck of a lot of heat exiting that fan port on the rear. As a minimum, I'd suggest paying heed to the recommended clearance in the owner's manual and you might need to add active cooling, i.e. fans to exhaust the heat from the enclosure.
YMMV
Jason Cald****
Thanks if anyone could email me a link to the post i would really appreciate it. Trying to figure out wether our not to go with this or a 50" Plasma.
BMan56
