Brian Burnaby
- Mar 14, 2002
Hello all,
I have a pair of PsB Image 5T's as my main speakers right now, and am ready to buy some surrounds. I need some advice on what size speaker I should get. I plan on later adding the PsB Image 9c as a centre, but for now I can't decide on the surrounds. The options are:
1) PsB Image 2b, I'll have the same size driver as the front speakers, but are they too big for rears?
2) PsB Image 1b, a smaller driver than the front speakers, but will they sound good with music?
I'm plan on using my surrounds for listeneing to music (Prologic), as well watching moives, which makes me think I should get the larger 2b's. But their so big... is it overkill?
Thanks for the advice.
Brian
(if it helps, my wife says she doesn't mind the larger speakers)
Brian
