Misanthropic75
- Apr 23, 2009
- Scott
The projector is about 7 months old, I sent it in for a recall for the control board, wire sensors and sensor board, they replaced them with new and improved boards/sensors. It is like a new projector again, when it was sent in to Planar in February of 2009 they also put in a brand new bulb. The casing is in very good condition. I only put about 100 hours on the new bulb. This is an awesome projector, the image it throws is amazing, especially with HDTV and Blu-ray/HD DVD. There isn't another new model 720p projector that can touch this in terms of picture quality that I know of. The projector will be shipped in its original box, it is still under 2 year factory warranty with Planar. I am not sure if it is transferable, but I would be willing to call for you if any problems came up.
I will ship via USPS Parcel Post and shipping price includes insurance. Feel free to message me if you have any questions. I will also include a 25' component cable and a DVI to HDMI adapter with the projector, as well as the remote and power cord. This projector retailed for $3,999.00 MSRP when first released, it is an all around amazing projector. I am willing to ship outside of the U.S., you would need to contact me for a shipping quote. If you live in Southern California and would like to come see it, or pick it up instead of paying for shipping, let me know.
[BSignal Compatibility
Video Support: HDMI and DVI with HDCP for digital video, Component and RGB HDTV (1080p, 1080i, 720p), Component and RGB EDTV (576p, 480p), Component, Composite and S-Video SDTV (576i, 480i), RGB SCART with adapter, NTSC/NTSC 4.43, PAL (B,G)/(D,K)/I/M/N, SECAM
Computer Support: Digital and Analog up to 1280x1024 @ 60Hz, Macintosh®
Communication: RS-232 (discrete commands and SW upgrades), IR remote, on-board keypad
Connectivity
(1) DVI-D: HDTV RGB and Component, DVI (Digital Visual Interface) with HDCP (High Bandwidth Digital Content Protection), HDMI via adapter
(2) Component (RCA): HDTV, EDTV, SDTV
(1) RGB (HD15): HDTV, Computer (Hsync 25~75kHZ, Vsync 50~85Hz)
(1) S-Video: SDTV
(1) Composite: SDTV
(1) 3.5mm mini jack: 12V screen trigger (0.25 Amps)
(1) 9 Pin D-sub RS-232
Performance
Microdisplay: Texas Instruments DLP® DarkChip™
Native Resolution: 1280 x 720 (921,600 pixels)
Aspect Ratios: Native (Pixel-to-Pixel), 16:9, Letterbox, 4:3, Anamorphic compatible
Projection Lens: All glass, F/2.4~2.50, f=19.1~23.9 mm, 1:25x manual zoom, made in Japan
Throw Ratio: 1.3 - 1.7 (distance/width)
Lens Shift (optical): +/-15% (horizontal), +115%, -100% (vertical, ceiling mounted)
Video Lumens: 900 ANSI max
Contrast Ratio: 4500:1 (max full on/full off)
Cooling Performance: High efficiency adaptive voltage side-to-side cooling with low system acoustic noise level (29dBA) and low light pollution cabinet
Projection Modes: Front, Rear, Ceiling (front/rear)
Keystone (digital): +/-5° (horizontal), +/-5° (vertical)
Lamp: User replaceable 200/250W HPM (selectable), 3000 hour average lifetime*
Video Processing: Pixelworks™ DNX (Digital Natural Expression) 10 bit video with Motion-Adaptive De-Interlacing, rich color processing and noise reduction.
Calibration: Full RGB gain/offset control (White Balance), Gamma (1.0, 1.5, 1.8, 2.0, 2.2, 2.35, 2.5, 2.8), Contrast, Color Temp (Presets 5K~10K and X,Y control for R,G,B,Y), Brightness
General
Dimensions: 17.5" (445mm) L x 16.5" (420mm) W x 6.5" (164mm) H
Weight: 17.6 lb (8 kg)
Operating Temperature: 32° F (5° C) - 95° F (35° C)**
Operating Altitude: Sea Level - 7,500 Ft (2,300m)
Operating Humidity: 0% - 80% non-condensing
Universal Power Supply: 100V - 240V at 50-60Hz (auto-ranging), true soft power
Regulatory: FCC Part 15 Class B, CE Class B, UL, cUL, CB, RoHS, WEEE, local conformances as required
Menu Languages: English, French, Italian, German, Spanish, Traditional Chinese, Japanese, Korean
Here is a link to a couple of reviews:
Planar Projectors: Planar PD7130 DLP projector
][/b]
Connectivity
(1) S-Video: SDTV
(1) Composite: SDTV
Performance
General
][/b]
