John Wachter
- Mar 13, 2004
Periodically I'll first run the Martin Logan ARC mobile calibration and move the mic around to the different locations in the room, then run the Pioneer's MCACC. Paradigm studio 60 speakers set to small. I noticed when I'm done running the MACC it says the crossover is at 100. I thought it was more common to be 80, does 100 sound right?
I don't tweak the sub after calibrating it except volume, if I wanted to manually control anything I wouldn't be able to use the calibrated settings, and I MIGHT have to turn off the Pioneer's MACC settings to change the crossover (not at home right now)
It sounds ok, just wondering if it can sound better, but the calibration for both AVR and sub are there for a reason. Any input appreciated
