Pins or bare wire (1 Viewer)
John Gido
Unfortunately, most of my speaker connections are the spring-clip type. I am using 14G speaker wire inserted into the spring-clips. Would there be any benefit to using pin connectors instead of bare wire other than the obvious (stray wire to short, neatness, etc.)?
Chu Gai
you can get the pins gold plated...then corrosion/oxidation isn't an issue.
Jim_C
I would go with bare wire. I've tried pins in spring clips and you can wiggle them around and slide them. The connection is more secure IMO with bare wire. I don't use pins for anything. Strictly bananas and spade connectors.
Juan Castillo
what about spring terminals with tinned speaker wire ends? Lots of advocates of this method, and that is basically the same as a pin.
QuirkyProtection
