Mike Boeckeler
Grip
- Aug 27, 2002
Hi
Last week I bought the 30" 16:9 Samsung, and although I really like it, I think that I am going to go all the way and spend four or five hundred dollars more and buy a RPTV.
For $1599 I can buy the 47" Panasonic 47WX42. When I was buying my Samsung last week I looked closely at this Panasonic and really liked it. From the Panasonic website I see that the 47WX52 is almost identical - and the main difference appears to be a screen shield.
First, is this considered a good TV? Would I be better off buying a different RPTV for about the same ammount of money?
How crucial is a shiled like this? Is it worth the extra $$$$? Or is it something I can buy and install in the future if I decide I need it?
And I am concerned about my center channel speaker - I cant remember if there is room on top of the TV to put a center channel speaker? If not, where do you put it?
Does a TV like this need to be installed by a professional, or is it as easy as unloading it out of its box and plugging it in (I know its heavy!)?
Sorry for so many questions - I am new to HDTV and want to make sure I dont make a $1500 mistake!
Mike
Mike
